Author Topic: Need help with Vray Proxy Objects  (Read 15844 times)
loydering
    • pbviz.com
« on: October 14, 2008, 06:19:10 pm »
Alrighty.  So I've got a scene set up to use VRay proxies as my custom objects but I'm having some issues with display and renders.  The Vray Proxy was exported from and Onyx Tree object.  The display issue involves toggleing between "bounding box" and "preview from file" modes within the MeshProxy Display prameters.  In the Forest Pro Object, When I have the bounding box mode on for the proxy object, it displays as a box.  No problem there.  But when I render it out I get a scene full of beautiful boxes (which would be awesome if that's what I intended to do).  So, I thought that by setting the proxy object to preview from file mode, it would fix it.  You guessed it; only works in theory.  Instead of showing the preview objects, it reverts to planes and the distribution also changes.
Any suggestions?  Oh yeah: Max 2008 64x.  I have some attached screen caps below.
« Last Edit: October 14, 2008, 06:20:49 pm by loydering »
Re: Need help with Vray Proxy Objects
« Reply #1 on: October 14, 2008, 10:56:02 pm »
You must use Forest Tools to convert the trees to instances of the proxy object:
http://www.itoosoft.com/english/menu.php?id=forest_tools
You get only planes from Forest because the number total of faces exceeds the limit defined in "Display" rollout. But this is normal for the most of scenes that use VRay proxies, so Forest Tools is used to create a proxy by each tree before rendering the scene.
George
« Reply #2 on: March 22, 2011, 09:10:31 am »
Is there the reverse of that tool so I can convert VRayProxy objects to an FP object?
« Reply #3 on: March 22, 2011, 05:54:45 pm »
Besides using Maxscript, you would use Creation Tools->Reference Object->Pivot Point, to create items based on the position, rotation and scale of the proxies.
George
« Reply #4 on: March 23, 2011, 07:11:56 am »
Can I access the list of custom-placed instances? I couldn't find it by looking at the API exposed by using "show $".
« Reply #5 on: March 23, 2011, 12:51:42 pm »
You must use showinterfaces($):
http://itoosoft.com/forestpack/reference/install.php (see Maxscript section)
George
« Reply #6 on: March 24, 2011, 05:24:49 am »
Oh neat! I didn't know about that command - thanks Carlos.
