Author Topic: Forest doesn't stay inside spline?  (Read 3716 times)
LN3729
« on: June 24, 2016, 11:13:02 am »
I am experiencing a pretty annoying problem with Forest Pack. I have created a spline that I wish to create a forest in (to scatter some grass). However, when I click on the spline to create the forest the scattering is translated slightly outside the spline.
I have attached a screenshot. (I am refering to the grass-area, not the trees by the way. The trees aren't using Forest Pack).
LN3729
Re: Forest doesn't stay inside spline?
« Reply #1 on: June 24, 2016, 11:21:23 am »
Just tried it on another spline, the problem persists.
« Reply #2 on: June 24, 2016, 11:34:56 am »
Thanks for contacting us. Are these spline imported from another package? If so you could try using the Reset XForms operation before adding the Forest object. Otherwise if you could send us a scene with one of the problematic splines so we can check the issue in more detail that would be great. If you'd prefer not to share it here please feel free to send it to support@itoosoft.com and we'll take a look.
Many thanks!
Paul.
