Author Topic: question on creating forest objects in a scene  (Read 4935 times)
MQ4267
« on: September 08, 2017, 11:33:04 pm »
recently, i happened upon a tutorial (i believe on itoosoft) that seemed to show that a forest object can contain another forest object as it's objects!  i tried it a couple of times and it seems like it works.
i created 5 blades of grass as edit poly's, then i created a small diameter circle, created a forest object on that circle, then clicked custom objects and added all 5 blades of grass.  then, i created another forest object on a surface, custom object and picked forest object #1.
any edits i make to the first, smallelr forest objects seem to be reflected in the larger one.  for example if i increase/decrease the radius of the small circle.
is this "ok" practice?  or has it always been the case and i just never thought of it ha!
thanks,
Re: question on creating forest objects in a scene
« Reply #1 on: September 09, 2017, 08:56:50 am »
Yes, this is a correct procedure. Forest supports nested objects since some time ago.
In fact, we have a small tutorial describing this technique. You can find it here.
MQ4267
« Reply #2 on: September 29, 2017, 03:07:37 pm »
sweet!  and that's even the tutorial i saw!  thanks!
