Author Topic: Use network paths for library & textures.  (Read 14190 times)
eqko
« on: October 30, 2025, 03:14:38 pm »
Ok, so the main issue is this:
When using Ivy and rendering on the network, the rendernodes can't find the textures.
Which makes sense, since the textures have no paths in them  when picking the material from an Ivy preset.
And when pressing the bitmap, it goes to a user path:
Code: [Select]
C:\Users\username\AppData\Local\Itoo Software\Forest Pack Pro\lib\ForestIvy\Climbing PlantsWhich doesn't work for us, since we render under a different username (a specific render user)
So the logical solution would be for Forest and Railclone to use a central network location for textures and presets and whatnot.
And here comes the crux: I know there have been a couple of threads about this, and I perused them all. But you'll have to forgive me that I can't see the forest for the trees (bad pun, but no less valid).
I am kind of unclear about the whole procedure of setting up a single iToo network repository so that:
  • All workstation will use the repository as library for both Forest and Railclone presets (I need the regedit approach for this?)
  • Both Forest and Railclone will use the repository to look for needed textures when using a preset from the library (Is this what I use maxini for?)
I've read about regedits, environment variables, max ini edits, settings settings in the Update Manager.
Regarding points 1 and 2, the reason I come here is because I need an approach where I can use a batfile or something to inject info. I have 50 rendernodes and 40 workstations, I do NOT want to have to do anything manually per node if I can helpt it.
I think it might be a good idea for you to setup a single dedicated page for this somewhere instead of pointing users to various threads.
You guys are great at writing tutorials ;D
Re: Use network paths for library & textures.
« Reply #1 on: October 30, 2025, 03:34:13 pm »
There are several possible ways to set this up, and it mainly depends on how you manage other assets in your scenes that are saved across your network. You can configure textures for ForestPack or RailClone objects in the same way as any other textures — there’s no difference. Textures for items handled by our plug-ins are treated just like any other assets in the scene.
I’d suggest checking this closely related thread - I hope it helps.
RealViz
    • RealViz
« Reply #2 on: October 30, 2025, 03:59:06 pm »
I would also like to simplify the procedure. For me, it would be ideal if the installer would already have the option to select the path and thus would not unnecessarily install about 12GB (not even that much in today's terms, but...) of data on the local disk and just update it on network when reinstalling/update.
ZO6039
« Reply #3 on: October 31, 2025, 05:32:47 am »
+1 vote for installing FP library on mapped network drive - one library for all computers. Your current setup for this in not pretty clear. Please make installer asking library folder.
eqko
« Reply #4 on: October 31, 2025, 12:23:47 pm »
I understand the need to cater to less technically inclined customers, but I think a simple 'advanced' install option to point to and install everything on a network location would save a lot of headaches. Especially for rendernodes to be able to find textures on the netwerk location.
Because attached fp_1.jpg is just shenanigans if you ask me.
Specifically the fact that it shows no path, but when you click the bitmap, (fp_2.jpg) it goes properly to a userfolder with the textures ...
And no, repathing them to the server everytime \ every project \ every file is not a very valid option ...
I could use a clear answer for that last part where max 'knows' the location to look for the textures is the network location and not my user folder.
And with that, a clear way to roll this out over all our rendernodes and workstations  ;D
RealViz
    • RealViz
« Reply #5 on: November 03, 2025, 06:50:35 am »
But it's not just about convenience or less user experience. It's about the principle itself, where FP/RC installs its entire library on all PCs. As I wrote. It's not much (12GB), but it's completely unnecessary even considering that most users have the library on a network share anyway.
« Reply #6 on: November 04, 2025, 10:23:36 am »
We're currently working to improve this. According to your requests, there are two problems to solve:
a) Change the installation path for the assets.
I think this is doable, and will require some changes to the Update Manager.
b) Relink textures to the library path, so it's not required to use the 3DS Max texture folders.
This is more complex, because Max doesn't provide any automatic way to relink textures using the Asset Tracker (only can be done manually). I'm trying to implement a custom tool for that.
No promises, but i hope we can provide a solution for both issues on next updates.
RealViz
    • RealViz
« Reply #7 on: November 04, 2025, 12:08:15 pm »
Thank you, that sounds great!
RealViz
    • RealViz
« Reply #8 on: November 05, 2025, 12:35:10 pm »
And wouldn't it be enough to add a folder on the network to the External Path? That would solve everything, or am I wrong?
Just as the road is now e.g:
C:\Users\%%%%\AppData\Local\Itoo Software\Forest Pack Pro\lib\Presets\Cut Hedges\maps
it will be e.g:
x:\Itoo Software\Forest Pack Pro\lib\Presets\Cut Hedges\maps
« Reply #9 on: November 05, 2025, 01:46:30 pm »
it will be e.g:
Yes, but some users don't want to deal with the External Paths (or don't understand well how it works), and want the texture file is linked to the library location, including the full path.
Currently, this only can be done manually using the Asset Tracker.
Also, if External Files includes two paths with the textures (for example, one local and other in the network), the Asset Tracker will solve the file using the first path in the list.
« Last Edit: November 05, 2025, 01:48:18 pm by iToo »
RealViz
    • RealViz
« Reply #10 on: November 05, 2025, 03:19:11 pm »
it will be e.g:
Yes, but these paths are added to the ini by the FP installation. If the installation changes the path to a user path, the user path will be added to the ini as well and it will not be "C:\user\....." So there's no duplication, or am I missing something? :-)
« Reply #11 on: November 06, 2025, 08:52:25 am »
With a new clean installation that's correct. But i'm assuming extreme cases, as paths added from a previous installation, manually added by the user, etc.
The relink method will guarantee that assets are loaded from the path of the selected library.
Anyway, it's just a new option (disabled by default) available to anyone who wants to use it. We'll maintain the current procedures for External Paths.
ZO6039
« Reply #12 on: November 20, 2025, 04:22:01 am »
I don't like idea of automatically searching textures in the paths what 3ds Max does using Project Paths/External Files. All textures should include the path to library. Even if I rare use any objects from library I constantly get a message about changing paths when I switch Max project folder.
« Reply #13 on: November 20, 2025, 12:00:25 pm »
Next Forest update will include a "relink" feature as option. Using it, library textures will include the full path to the library.
