Author Topic: BUG: Reference distribution doesn't show all the trees in viewport  (Read 3627 times)
DT
When using references as a way to distribute trees for instance, I found that it sometimes omits certain scattered objects from display in the viewport. See video uploaded here: https://youtu.be/NxUCFbfpJC4
Re: BUG: Reference distribution doesn't show all the trees in viewport
« Reply #1 on: May 12, 2023, 01:06:07 pm »
I’m sorry to hear, you’re facing these troubles. Which version of the Forest Pack plug-in are you using? In the Forest Pack Lite/Pro 8.0.4 we added the following fix: “Distribution->Reference mode doesn't work well with mirrored references.” I wonder if that might be related.
DT
« Reply #2 on: May 12, 2023, 01:23:04 pm »
I'm using 8.0.7. I'm going to update and try again but I don't think it has anything to do with mirrored references will check their scale.
