Author Topic: BUG REPORT - area exclude scale difference between v7 and v8  (Read 4693 times)
JK1258
« on: December 07, 2022, 01:26:49 pm »
After switchiing from FP v7.xx to FP 8 i realized that in one of the FP created six months ago i have much bigger plants that before.
It looks like area exclude scaling gives different values in V7 and V8. I had to multiply the explude rande like two times to acheive more or less the same effect.
I have attached a scene with plants converted to boxes. Ofiginally they were CProxy objects.
Mike.
Re: BUG REPORT - area exclude scale difference between v7 and v8
« Reply #1 on: December 07, 2022, 01:51:28 pm »
I'm sorry to hear, you're facing these troubles. As I can see, you’ve been using version 8.0.4 and it’ll be most probably related to an already fixed problem - since the Forest Pack 8.0.5: "Fixed error computing distance from item to an area (used in Falloff, Edge Mode, and other features)." The latest version (at the moment the Forest Pack 8.0.6) can be downloaded from the User Panel under Downloads - My Products.
JK1258
« Reply #2 on: December 08, 2022, 11:00:51 am »
Thank You,
I will try it out. I am sure it will be OK. I just missed an update. My bad.
Mike
