Author Topic: Forest objects not on surface  (Read 2654 times)
ST3200
« on: December 19, 2022, 02:34:53 pm »
I wanted to distribute objects on a plane.
If I rotate the plane or I deform it ( of course I update surface ) objects pivot is not on the surface... (???)
Re: Forest objects not on surface
« Reply #1 on: December 19, 2022, 02:42:45 pm »
Please try resetting the XForm of the surface after you've moved it, that should fix it. Forest Pack expects its Z-Axis will align with the surface's for surface hit calculations.
ST3200
« Reply #2 on: December 19, 2022, 03:21:31 pm »
ooooopppsss.... you're right !  ;)
