Author Topic: Bug? with surface UV mode  (Read 5616 times)
George
« on: June 21, 2012, 08:47:32 am »
The problem being that the items align not to the surface normal, but the UV normal, so if the UV is flipped, so is the item. This is further compounded by the fact that the viewport shows it as surface aligned. I'd much rather it stayed surface aligned!
This only occurs when mixing alignment between normal and up, so i'd say the up-vector is basing itself on the UV derived normal rather than the surface normal.
(see attached).
« Last Edit: June 21, 2012, 08:52:30 am by George »
Re: Bug? with surface UV mode
« Reply #1 on: June 21, 2012, 09:43:02 am »
Yes, there is a strange behaviour with some values of Direction, specifically 0, below -45 and above 45. Anyway, in my tests i don't see any difference between viewport and render.
Please, send us a test scene to check this issue using your surface. We will investigate it further.
« Reply #2 on: June 23, 2012, 12:07:05 pm »
Solved by e-mail using a custom patch. If someone has the same problem, please contact us at support@itoosoft.com.
