Author Topic: camera clipping  (Read 13267 times)
grue
camera clipping
« on: June 04, 2024, 10:22:06 pm »
i have camera clipping turned on and the distance set appropriately (~200ft from the camera). i have it set to perspective/camera in the forest object. when i hit render, i get all the grass over the whole surface even though i'm on the viewport of the camera, but in the other viewports all the grass shows up.
is that expected behavior?
Re: camera clipping
« Reply #1 on: June 05, 2024, 08:35:38 am »
The Limit to Visibility feature should be considered during rendering. Have you manually assigned the Camera for the Limit to Visibility feature? If left empty, the Camera is automatically taken from the render view. Which renderer are you using?
If you continue to experience issues, it’s difficult to diagnose the problem without seeing the scene. If possible, please feel free to send us your scene - ideally simplified and containing only the problematic object(s). Thank you in advance for any further details you can share with us or our user community, as it may help others who encounter similar issues.
grue
Re: camera clipping
« Reply #2 on: June 05, 2024, 04:13:58 pm »
i did not have a camera selected.  let me give that a try.
