Author Topic: Camera Clipping Not Working Forest Pack 7.1.2  (Read 6275 times)
tonyinseattle
« on: August 22, 2021, 12:50:44 am »
Hey, everyone... I can't for the life of me get Camera Clipping to work. I can get it to "work" in the viewport, but when I render, clipping is completely ignored.
In the attached, I have a gray plane that I'm populating with pink boxes via FP. I've set enabled "Limit to visibility" and Enable on Viewport I/R, which I set to "Cameras" (though I've tried all options here). In the Viewport, I see the scene as expected, with the pink boxes only in the foreground. Same with top view. But when I render either view, I get pink boxes all across the surface -- no clipping.
Using Arnold for rendering. Latest 3ds Max 2022 64 bit.
Any ideas?
« Last Edit: August 22, 2021, 08:16:33 am by tonyinseattle »
Re: Camera Clipping Not Working Forest Pack 7.1.2
« Reply #1 on: August 23, 2021, 11:16:22 am »
Big thanks for the provided scene. With your help, we've been able to reproduce this behavior here too. We'll continue analyzing this issue - it'll need to be investigated more in deep by our main developers and hopefully, a solution will be found soon. Meanwhile, the Render > Mode: Meshes could be used to apply settings from the Limit to visibility feature when using the Arnold renderer. Just take in mind, that it "disables the instancing power".
tonyinseattle
« Reply #2 on: August 24, 2021, 02:18:34 am »
Thanks for the reply. I hope it gets fixed soon. I rely heavily on camera clipping and instancing.
« Reply #3 on: November 01, 2021, 10:22:41 am »
tonyinseattle
« Reply #4 on: December 30, 2021, 01:31:28 am »
Hey there... are you sure? I did not have a chance to install 7.2.1, but it doesn't appear to work in 7.2.2. See attached and file. Am I doing something wrong?
Tony
« Reply #5 on: December 30, 2021, 08:49:25 am »
Hi, in your scene the Back Offset parameter is too high.
Just lower it, and (optionally) turn on Enable on Viewport, to see clipping working.
tonyinseattle
« Reply #6 on: December 30, 2021, 07:10:56 pm »
That works. I think I clicked "Enable in Viewport" and when I didn't notice a change, I reset it. Then I played with back offset and still didn't see a change. The key was to adjust BOTH. Thanks!
