Author Topic: Nested Forests not rendering in Corona Renderer  (Read 4768 times)
GH2227
« on: March 31, 2014, 07:25:35 pm »
Hi, Im currently using Forest Pro v. 4.1.6 in 3ds Max 2013. Im trying to render a scene with nested forests to distribute over a grass surface. When I try to render nested forests with simple objects (basic spheres) they render correctly. When I try to use grass models in the same scene they wont render.. If I change to Vray it will render.. can you fix this issue with Corona render please? or is there any solution for this? thank you for your time
Re: Nested Forests not rendering in Corona Renderer
« Reply #1 on: March 31, 2014, 07:39:19 pm »
Please, try changing in the inner Forest object: Display->Render->Mode from Automatic to Meshes. That should solve the problem.
GH2227
« Reply #2 on: March 31, 2014, 07:46:33 pm »
Thank you for your fast response, that solved the issue! thanks again
