Author Topic: Camera limit & Batch render  (Read 4614 times)
IT1371
« on: October 27, 2015, 06:12:59 pm »
Is there any news about Camera visibility limit and Batch Render problem? Or some alternatives to 3Ds Max Batch Render that does work with Forest?
My forest objects are getting more and more complicated and I have to keep camera visibility on because otherwise it render double-time or crashes.
Re: Camera limit & Batch render
« Reply #1 on: October 28, 2015, 11:17:30 am »
Upon our tests with latest 3ds Max (2016) & V-Ray (3.20.03) the Camera - Auto assign to active view feature / Apply to Look At (I suppose you are referring to those) works fine while using the Batch Render. We've tested it successfully with 3ds Max's Free camera, VRayPhysicalCamera and latest Physical camera.
In case you'll be facing any issues with it, please let us know. Thanks in advance.
IT1371
« Reply #2 on: October 28, 2015, 12:25:41 pm »
Does it also work when changing cameras with the batch render?
« Last Edit: October 28, 2015, 12:39:30 pm by 3dcrgr »
« Reply #3 on: October 28, 2015, 12:37:14 pm »
Yes, the Auto assign to active view feature correctly assign the camera used by the Batch Render (when rendering multiple "views" it's reassigning the corresponding camera for each of those).
IT1371
« Reply #4 on: October 28, 2015, 12:41:50 pm »
Thank you, I will try it tonight.
Does it also work with V-Ray 3.25 nightly? I am on 3.20.02 at the moment and if I update it I probably pick a more recent version then 3.20.03.
« Reply #5 on: October 28, 2015, 12:51:25 pm »
As far as we know there are no changes in the V-Ray 3.25 build respect it and it should work without any issues.
Kind regards,
