Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Problem follwing spline
« previous
next »
Print
Pages: [
1
Author
Topic: Problem follwing spline (Read 31385 times)
RJ1367
Newbie
on:
June 15, 2008, 11:47:23 am »
For some reason my trees will not follow a glued spline. The spline is glued to the surface but when the gl spline is used to create the forest it is created above the glued spline on a flat plane. I'm sure there is something simple causing this but have tried all of the options in glue and forest to no avail (I am glueing to the gl line and not the normal line).
Hope you can help I have a lot of hills to populate with trees.....
Geoff
Edit- just tested it and it is actually glueing the trees to the original line even when I select the gl line- have tried deleting/hiding the original line and reinstalling glue....
Last Edit: June 15, 2008, 11:53:38 am by RJ1367
Logged
Administrator
Hero Member
Re: Problem follwing spline
Reply #1 on:
June 15, 2008, 12:07:12 pm »
You can't use glued splines with Forest, because a spline doesn't have the the elevation data needed to place the items correctly. Use the "Surface" options of Forest Pro to link the trees over the terrain.
Logged
RJ1367
Newbie
Reply #2 on:
June 16, 2008, 10:49:24 am »
Thanks I realised my mistake just now!
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
