Author Topic: Is there a way to have grass scale in the Z axis automatically?  (Read 3642 times)
steve3duk
« on: September 19, 2022, 02:31:15 pm »
...due to an object moving across it...so, for example, a car pushing the grass down due to the tyres squashing it?
Re: Is there a way to have grass scale in the Z axis automatically?
« Reply #1 on: September 19, 2022, 03:24:37 pm »
Hii,
There are several ways how to archive it – you might find interesting the "Striped lawn and ivy" part of our "Rendering a Modern Barn scene with Forest Pack" tutorial showing how to use a map to drive "Transforms". Also, you might consider checking the "Animating in Forest Pack" tutorial where under the Set the starting frame with a map part you can find another suitable solution. Another possibility would be to use the Effects feature - apart from the Effects part of our online documentation which includes also some examples, I would suggest you check our "Introducing Forest Effects" tutorial.
