Author Topic: Camera visibilty - vraycam offsets  (Read 5848 times)
Peter Guthrie
« on: March 17, 2013, 08:15:26 pm »
Would it be possible to make forest recognise vrayphysicalcam horizontal and vertical offsets? It works fine with a skew modifier on top of the vray cam to do the same thing, but not with the native vrayphyscam ones.
Thanks!
Re: Camera visibilty - vraycam offsets
« Reply #1 on: March 18, 2013, 09:04:39 am »
As far i can see, camera clipping reacts correctly with the offset changes. Please, would you post a screenshot with the problem ?
Peter Guthrie
« Reply #2 on: March 18, 2013, 12:12:33 pm »
Did you try rendering that? It seems to work fine in the viewport, but not when rendering (you may need to use quite a big offset to get it to show the problem)
(I just noticed I'm on 4.01, will upgrade to 4.02 and check if it fixes it)
Peter Guthrie
« Reply #3 on: March 18, 2013, 12:20:33 pm »
same thing with 4.02
« Reply #4 on: March 18, 2013, 01:43:35 pm »
Yes, you're right... it doesn't work at render (i didn't tried that).
I don't know if the problem is ours or VrayPhisycalCamera is returning some wrong value. We will check it.
Peter Guthrie
« Reply #5 on: March 18, 2013, 03:35:18 pm »
the most recent release of vray fixed a problem where the viewport representation of the offset didnt match the rendered output - maybe that affects things?
Peter Guthrie
« Reply #6 on: March 18, 2013, 03:46:34 pm »
Do I win something for finding a bug? :)
« Reply #7 on: March 20, 2013, 12:51:45 pm »
I just wrote to ChaosGroup. There is a difference in some of the values returned by the camera at render time, compared with the viewport.
Hopefully you win a patch... but not an eye patch ! (those are in other less recommendable forums). ;D
