I am making a style for a banister, and I have posts assigned to the Corner node. However, when I have a post on a vert where the spline turns, and turn off Bend and Slice to see the full post, it's turned 45 degrees (see pic).
Is there a way to automate that the post automatically turns 45 degrees on Z when in that position? I have not yet found a way that doesn't involve manually changing vertex types.
Thank you!
