Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Can't get rid of "Some Forest Pack items were not built correctly..." error
« previous
next »
Print
Pages: [
1
Author
Topic: Can't get rid of "Some Forest Pack items were not built correctly..." error (Read 4118 times)
SC5342
Newbie
on:
April 23, 2021, 12:30:30 am »
Using Forest Pack 7, latest version and MAX 2021 (latest version). Arnold renderer.
I read this document about the above error.
https://docs.itoosoft.com/kb/forest-pack/some-forest-were-not-built-correctly-in-the-last-render-error
I kept reducing the number of objects, but I kept getting the error. Finally, I removed ALL geometry from that Forest item, and the error was still there. I have another Forest Item in the scene that produces no errors when I render.
Scratching my head here. I've got other scenes using ForestPack with millions and millions of objects (vast wheat fields) and I get no errors.
Anything else to check?
Thanks.
Logged
ITOOSOFT
Hero Member
Re: Can't get rid of "Some Forest Pack items were not built correctly..." error
Reply #1 on:
April 23, 2021, 08:54:58 am »
I'm sorry to hear you're facing these troubles. Under the
General
Forest Stats
window you can check more details about that Forest object and it should give you a hint, where the problem might be. Also, please feel free to send us the simplified scene (containing problematic Forest object(s)) through
WeTransfer
to
helpdesk@itoosoft.com
to check it here. Thanks in advance.
Logged
SC5342
Newbie
Reply #2 on:
April 23, 2021, 03:31:57 pm »
Thanks Michal. I ended up just deleting the Forest item and rebuilding it. Whole scene is working fine now with just as many iterated objects as before. Probably something I did in the original Forest setup that caused that issue.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
