Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Can't map planes to surface
« previous
next »
Print
Pages: [
1
Author
Topic: Can't map planes to surface (Read 110892 times)
UG1259
Newbie
on:
November 13, 2007, 10:46:50 pm »
I am selecting a closed spline to define my forest area and then I put them onto a surface using the modify panel under the Surface pulldown. It's placing some onto the surface and leaving others at their original elevation. I am using a surface that I created in Civil 3D, but it doesn't seem to be the problem. Any thoughts?
Logged
Administrator
Hero Member
Re: Can't map planes to surface
Reply #1 on:
November 13, 2007, 11:06:17 pm »
We need to check the scene to find the problem. Please, send us the file (only the essential objects) to support@itoosoft.com
Logged
UG1259
Newbie
Reply #2 on:
November 13, 2007, 11:13:11 pm »
I found out the problem is that when forest places the planes, it places some outside of the spline and my surface is only inside of the spline. Is there a way to only place within the closed spline? This should fix my problem.
Logged
Administrator
Hero Member
Reply #3 on:
November 14, 2007, 04:18:44 pm »
Forest must place the trees only inside the spline, if not there is some problem. The only exception, is when using a random translation, that may move the planes outside the area... have you that option enabled ?
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
