Author Topic: Revert default preset when creating new FP objects  (Read 2865 times)
TQ2762
« on: November 30, 2021, 08:21:14 pm »
I am having a hard time using custom default presets and would like to revert to "factory default".
Since i edit some parameters, don´t know why when i creat a new FP, the "Area" tab is greyed out and the surface are toggle is off by default. Everytime i create a new FP, i have to manually assign a surface and toggle on the area surface.
Is there a way to revert it to factory?
Re: Revert default preset when creating new FP objects
« Reply #1 on: December 01, 2021, 08:47:46 am »
Presets are stored at C:\Users\<user name>\AppData\Local\Autodesk\3dsmax\<max version>\ENU\en-US\plugcfg\forest_presets.ini.
You can remove this file to restore the default settings.
Anyway, unless you created a preset with the name "default", other presets should not affect to new Forest objects.
TQ2762
« Reply #2 on: December 01, 2021, 03:13:33 pm »
Thank you. Worked fine.
