Author Topic: Can you add a few forest packs as a single preset in the library?  (Read 16554 times)
Rhodesy
I can't seem to find anything on this but it might be a forest set thing. I've created a wildflower meadow scene that uses three forestpacks to create the meadow. I would like to be able to save the three forestpacks as a single preset in the library. Currently I can just do one by one so I need to create a forest pack in the new scene then import the first preset then repeat for the next and then the next and then add the surfaces and areas. Is there a quicker way to combine all three so they can be imported once? I have three because they use different assets and scatter options for each one.
Rob
Re: Can you add a few forest packs as a single preset in the library?
« Reply #1 on: July 02, 2025, 08:14:11 am »
Hi Rob,
I'm afraid, that as mentioned in this tightly related post - at the moment, the Library Manager does not support handling multiple Forest objects. These objects need to be handled separately, as individual Forest objects. This is similar to the case of our Layered Lawns presets. The same applies to importing - although it is possible to import several items from the library simultaneously, these layered presets need to be added to the scene one by one. This is because a new Forest object is required for each of these presets. We'll see what can be done in future versions.
Rhodesy
« Reply #2 on: July 02, 2025, 10:12:28 am »
Thanks Michal, I can stop looking at least. Yes adding this as a feature would be very powerful and hopefully not too much effort if you can get the forest library to import multiple fp objects at once as a start.
nubo
« Reply #3 on: December 12, 2025, 09:34:42 am »
+1
Is it being considered for development in some near future?
That feature would be awesome, we have a lot of multilayered presets that usually utilize common ForestSets to drive the includes and excludes areas, and setting it up every time is a bit time consuming.
Looking forward for this feature. :)
