Author Topic: Can you recommend a lowpoly European Tree Library for Masterplans?  (Read 11798 times)
Morne
« on: September 22, 2025, 12:54:20 pm »
Hi guys
Can anybody recommend a good looking low poly European tree library, for use at masterplan drone/aerial views, but also for mid range eye level views?
Currenlty we're using a mixture of some of the Itoo 3D tree samples, Laubwerk, and Evermotion trees, all in Forest Objects, and rendering with Vantage.
Things have been working fine, but we are working on larger and larger scenes, and just want to be a little more efficient with our assets, especially if its only 5 pixels big in an image....(or little bigger for mid range eye level shots)
DT
Re: Can you recommend a lowpoly European Tree Library for Masterplans?
« Reply #1 on: September 25, 2025, 01:25:04 pm »
Hi guys
Maxtree has some LowPoly libraries as well: https://maxtree.org/product-tag/low-poly/ Or if you have access to the growfx versions of highpoly models, you can always use that to generate lowpoly variations of the trees.
Evermotion also has a lowpoly set: https://evermotion.org/shop/show_product/archmodels-vol-171/13123
RealViz
    • RealViz
« Reply #2 on: September 25, 2025, 04:10:35 pm »
Or try looking for an adequate one on FAB.com or sketchfab.com (e.g. https://sketchfab.com/3d-models/maple-tree-4b27adcf92f644bdabf8ecc6c5bef399 )
