Author Topic: Feature request: select surface/Areas objects in scene from Forest flyouts  (Read 3210 times)
Frood
Would be nice to be able to select the objects directly in the Surface/Areas flyout of a Forest object - something like a right click menu "select in scene" would be a huge time saver if that´s even possible. Any option (including a button if not avoidable) would do.
Good Luck
That's currently possible via the quad menu (right click over the Forest object) > Select Forest Surface / Select Forest Area. Hope that helps.
Frood
Hope that helps.
Ahh, thank you! Presumably I was to oldschool to check the quads (which I never use). Almost perfect!
Good Luck
