Author Topic: Find Out WHich Forest Items Your Scattering Automatiicaly  (Read 6191 times)
Lee H
« on: January 08, 2018, 09:54:23 pm »
Hi,i dont know if this is possible. Im working on a pretty large scene with loads of scatters.
While ive been tweaking the scatters i have ended up with loads of plant / grass /tree models in the scene. Some im using some im not. As they were Maxtree objects with a code rather than a name. Is there a way to auto select which geometry items your using for that scatter rather than having to manually keep clicking and finding the object
Re: Find Out WHich Forest Items Your Scattering Automatiicaly
« Reply #1 on: January 09, 2018, 09:34:23 am »
You can use the 3ds max's Select by Name tool and turn on Select - Select Influences. Now you can select the Forest object & related Custom Objects will be selected automatically as well.
Let me add, that you can easily select any used Custom Object via 3ds max's quad menu (right click) - Select Forest Custom Object.
Hope that helps.
Lee H
« Reply #2 on: January 09, 2018, 10:00:47 am »
Excellent - thanks so much.
Will save me alot of time
