Author Topic: V-Ray and Automaterial?  (Read 9219 times)
BQ2256
« on: May 31, 2021, 01:14:03 pm »
Is it possible to return that V-Ray uses Automaterial?
I had created a very practical geometry cutting system using VrayBlendMtl with an invisible material, this was done using Automaterial, and now I would have to do it for each geometry in the list, which would be a lot more work.
Regards
Re: V-Ray and Automaterial?
« Reply #1 on: May 31, 2021, 01:27:45 pm »
Would You please expand Your question ? I dont understand it.
BQ2256
« Reply #2 on: May 31, 2021, 01:47:01 pm »
In Forest Pack 6, I always used VrayBlendMtl to mix the Forest Automaterial, with an invisible material (Opacity 0), using a VrayDistanceTex that takes a geometry to make this mix.
This way I can cut Forest geometries that cross architectural elements without much effort.
In Forest Pack 7 this is no longer possible, it seems to ignore any material I create using the Automaterial it produces, this for me is a huge problem.
Would it be possible to work like that again?
BQ2256
« Reply #3 on: May 31, 2021, 01:50:29 pm »
As for "Automaterial" I use it the same nomenclature as it is in the Release Notes of Forest 7:
"Other Improvements
Supports GBUFFER - object  ID in V-Ray.
Added support for 'Instance ID' when using VRayUVWRandomizer and VRayMultiSubTex with Forest Pack.
Improved randomness for other Distribution modes than "Image". Previous versions would create visible patterns.
To keep the distribution of existing scenes, this is applied only to new FP objects.
If you want to "upgrade" your FP object so it works as created with FP7, select it and run from Maxscript: $.trees.resetCreatedVersion()
V-Ray now uses the materials assigned to each Custom Object, instead of the Automaterial."
« Last Edit: May 31, 2021, 04:10:50 pm by BQ2256 »
BQ2256
« Reply #4 on: May 31, 2021, 01:52:59 pm »
No matter how hard I try, I can't overwrite the material of a Forest object in version 7. I think this has changed between versions 6 and 7.
« Reply #5 on: June 01, 2021, 10:29:42 am »
Thanks for detailed explanation what You want to do.
We have never encouraged tinkering with forest automaterial. It is meant to be managed by ForestPack.
In ForestPack 7 it is used only for viewport. When rendering objects material is used unless overridden in objects material slot.
Anyway- You can create this setup manually.
I find rappatools (free version has this function too) to do the hard job- making shared multi-sub material for all the items.
Once it creates multi material, You can do the override blending as You used to.
Hope this helps
BQ2256
« Reply #6 on: June 01, 2021, 11:38:15 am »
Hi Rokas,
Thanks for the explanation, no doubt it's a way to help solve my problem.
However, in version 6, I was able to apply a material on the Forest object, it kept generating the Automaterial, but it rendered the material that I applied on top. This no longer seems to be possible in version 7.
Wouldn't it be possible to work like this again?
« Reply #7 on: June 01, 2021, 02:08:46 pm »
I am sorry, maybe You missed, above the workaround I have answered Your question already:
In ForestPack 7 it is used only for viewport. When rendering, objects material is used unless overridden in objects material slot.
There is no way/plan to enable this old behaviour.
BQ2256
« Reply #8 on: June 01, 2021, 02:10:18 pm »
Hi Rokas.
Ok, thank you for the reply.
Best regards
