Author Topic: Changing Forest Pack Grass Colour  (Read 9439 times)
smtenglishPF
« on: June 02, 2021, 04:12:51 pm »
I am having issues changing the colour of grass since forest pack 7.
I need to create artificial grass areas in various bright colours, previously I was able to create some grass using one of the presets in the library and then apply a simple V-ray Material with the correct colour to the Forest Pack object and that would change the colour. Since the release of Forest Pack 7 I no longer seem to be able to to apply a material to a forest pack object.
I have tried using the colour tint with 100% set to both the gradient values, but it only seems to effect part of the grass and not all of it?
Re: Changing Forest Pack Grass Colour
« Reply #1 on: June 02, 2021, 04:22:40 pm »
Hi. Have You pressed "optimize materials" yet?
In order for Color Tint to work there should be forest color map in the material.
I would gladly check Your scene if You attached a max file.
smtenglishPF
« Reply #2 on: June 02, 2021, 04:50:46 pm »
Yes I have, I have attached the max file.
if the link is broken to the textures in forest pack some how it seems to work ok, but I'm sure that's not how its meant to work!
« Reply #3 on: June 02, 2021, 04:55:42 pm »
no max file in either of Your posts.
