Author Topic: Cannot disable / hide RC and FPP Toolbars - they keep reappearing.  (Read 18871 times)
Re: Cannot disable / hide RC and FPP Toolbars - they keep reappearing.
« Reply #15 on: September 04, 2020, 08:50:37 am »
Unfortunately the situation has not changed. We will check autodesk SDK documentation again to check if we can improve that.
Arqrenderz
« Reply #16 on: May 18, 2021, 04:04:28 pm »
Is this fixed on V7?
I read about the lack of documentation, but this plugin is one of the only ones that has this behavior, so can you talk with your peers? vray, corona and so on can give you a hand??
suppenhuhn
« Reply #17 on: May 19, 2021, 09:43:24 am »
Having this issue as well - but for the first time!
I'm using Max 2019 - but the problem is only recently present. They're not reappearing but they're moving.
Since i made latest Updates to:
recently:
- RC & FP ( didn't noticed this issue after doing that )
latest all at the same day:
- Projectmanager ( Update to latest )
- Babylon JS Exporter ( Installed latest  )
- Windows cumulative Update KB5003173
« Last Edit: May 19, 2021, 09:54:51 am by suppenhuhn »
« Reply #18 on: May 19, 2021, 09:48:29 am »
That is not yet solved.
Temporary solution is to disable Itoo toolbars with regedit and create toolbar Yourself with required functions.
Arqrenderz
« Reply #19 on: May 19, 2021, 04:30:40 pm »
But the toolbar is very important for me :(
Is there any hotkey or any way to have the forest lister without the toolbar ?
« Reply #20 on: May 19, 2021, 08:07:45 pm »
Sure You can create that manually:
1 open customize User interface
2 choose toolbars
3 find "Forest Lister"
4 Drag it to the toolbar where You want it (or even create new toolbar Yourself with Your favorite functions)
5 Righclick to custsomize the button
6 choose Image Button
7 select fptoolbar group
8 select icon You like
Press OK.
Hope that helps.
Arqrenderz
« Reply #21 on: June 01, 2021, 06:17:25 pm »
THX Rookas! finally my viewport has returned!
