Author Topic: Suface dosent get Forset..  (Read 2910 times)
yossivida
« on: June 08, 2017, 07:18:39 am »
Hello i did vertical wall with forest ..
but when i chose the pink surface .. it dosent get the forest on it..
what i need to select to make it all walls covered by one forestpack modifier?
thank you!
amitgedia
Re: Suface dosent get Forset..
« Reply #1 on: June 08, 2017, 09:56:45 am »
hi,
you need to check this tutorial
https://www.itoosoft.com/tutorials/scattering-on-vertical-surfaces?back=page%3D1%26tag%3Dfp
also make sure the co-ordinates are in the right direction
also check this post where i had a similar problem
https://forum.itoosoft.com/index.php?topic=4354.msg16896#msg16896
hope this helps
