Author Topic: Select by colorID on Item Editor  (Read 24081 times)
CharlyRT
« on: January 27, 2024, 08:26:32 pm »
Hi there, is there a way to select objects that has the same color id on item editor? i have a variety of plants that i want to detach but some of them have 5 variations, and I can only select 1 object by type, i know that i can detach an reatach, but it could be helpful if we could have some kind of control while selecting objects, maibe store selections? o like I said, select by colorID  :-\
« Last Edit: January 27, 2024, 08:30:23 pm by RTstudio »
Re: Select by colorID on Item Editor
« Reply #1 on: January 29, 2024, 08:50:51 am »
An option would be to temporarily set all other items (apart from the desired Color ID) within the Geometry list to the Disabled mode to "hide" them. This will allow you to easily select the remaining objects in the Items Editor that should be detached.
