Forest Pack => Forest Pro (*) => Topic started by: RealViz on September 04, 2024, 04:02:07 pm
Title: Change item by distance to boundary - dosnt respect probability
Post by: RealViz on September 04, 2024, 04:02:07 pm
Hi, I'm trying to create an area border using an effect that will have specifi object. Everything works as it should, unfortunately objects mix with others randomly and do not respect the probability given in the geometry list. In the pictures you can see it on the white objects, which are close to the edge more than in the middle. If I set the white objects to 100%, it behaves correctly or as expected.
Any idea how to do that?
THX
Title: Re: Change item by distance to boundary - dosnt respect probability
Post by: Michal KarmazĂ­n on September 04, 2024, 04:20:06 pm
Please try the revised version of the 'Change items by distance to boundary' effects, which now only changes items at the edge. I hope that helps.
Post by: RealViz on September 05, 2024, 09:07:20 am
Fantastic! Thanks
