Author Topic: Transparency in viewport  (Read 12833 times)
RealViz
    • RealViz
« on: September 04, 2024, 10:37:34 am »
Hi, I have an idea for an improvement. Would it be possible to add a transparency option for proxies (Plane, box, plant etc)? This would often help when setting up cameras when now for example façade lines, windows etc are not visible. The only other option is pointcloud, but with that again we often don't see e.g. the trunk clearly. Thx
Re: Transparency in viewport
« Reply #1 on: September 04, 2024, 11:14:55 am »
For this purpose, you can enable the See-Through Display Property. I hope this helps.
RealViz
    • RealViz
« Reply #2 on: September 04, 2024, 11:24:47 am »
Yes, of course I know that. Unfortunately it doesn't provide any settings. Plus, we usually have everything on "by layer". Anyway, I understand that this is something that would require some further development and probably only I would use it :-)
Edit:
Plus see-through cancels colors :-(
Thx
