Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
How to unselect a library object?
« previous
next »
Print
Pages: [
1
Author
Topic: How to unselect a library object? (Read 2988 times)
EndlessX
Newbie
on:
April 20, 2022, 04:02:28 am »
Whenever I use forest pack with the default library it gets stuck with at least one item in it. Then when I go to scatter an item not in forest pack it will only use the item from the library. I want to select nothing and hit load and have it say 0 selected. The problem is that is impossible. How do I use forest pack selection after having used an item from the library?
Logged
ITOOSOFT
Hero Member
Re: How to unselect a library object?
Reply #1 on:
April 20, 2022, 08:15:24 am »
Within the
Forest Creation
rollout, you can right-click on the button under the
Library
section, which will "unload" the previously imported item / preset (it should say "
None selected
"). I hope that helps.
Logged
EndlessX
Newbie
Reply #2 on:
April 21, 2022, 07:13:37 am »
Hey great thanks for the answer. Very simple to do. You might want to make an change to the way this is done in the next patches. I would've never guessed to right click.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
