Author Topic: Chaos Cloud and FP 2D assets  (Read 3570 times)
HL1105
« on: March 27, 2023, 09:13:07 pm »
Hi All,
Chaos cloud is not rendering any FP 2D assets.
What am I doing wrong?!
Thanks for any help.
Re: Chaos Cloud and FP 2D assets
« Reply #1 on: March 28, 2023, 08:53:17 am »
I'm sorry to hear you're facing these troubles. Unfortunately, V-Ray Standalone isn't "fully" supported, and therefore neither is the Chaos Cloud - as mentioned in their documentation: "You can verify that your job will be processed correctly by rendering locally with V-Ray Standalone. If these results look correct, then you should get the same results in Chaos Cloud."
In the case of “billboards”, instead of using the Template option, please use the Custom Object and assign a material without the Forest Material (like in mentioned for example in this post).
