Author Topic: Chaos Cosmos Asset Odd Behavior  (Read 3407 times)
VelvetElvis
« on: May 04, 2023, 08:43:13 pm »
Does anyone know what the issue may be? In the attached image, the person that has the texture is the vray proxy from Chaos Cosmos. The same proxy is used in the forest below, but they all render in a solid color. I've hit a wall with this one and could use some help. If I use the mesh from the proxy, it renders fine. It seems the issue is related to the vray proxy and only if it is being scattered with Forest. All other cases, the proxy renders just fine.
VelvetElvis
Re: Chaos Cosmos Asset Odd Behavior
« Reply #1 on: May 04, 2023, 08:51:20 pm »
I solved the issue. It was for sure user error. I guess at some point, I had accidentally set the render mode from Automatic to mesh and it must have been just rendering the vray proxy preview mesh. Setting it back to automatic solved the issue.
