Author Topic: Installed Forest pro on 3ds max 2025 and vray 7, not able to scatter nothing  (Read 8725 times)
MT3905
I bought Forest pro today, because 3ds max 2025 and vray 7 did not support my old license.
I installet forest pro, and library (automatic)
I opened 3ds max 2025, and made a forest pro icon, chosed a surface and grass objects.
Nothing happened, i just got a RED "F" icon, tried to see if the path was ok, and it was.
I then installed 3ds max 2024, installed vray 7  and Forest pro for 3ds max 2024.
I get the same error when i tried to import grass and trees.
I then opened a new scene, made a 3ds max plane 13mx13m, i then made a box.
I made a forest pro icon, and tried to scatter the custom box on the plane.
I got the same error.
Forest pro does not work. Is there something i do wrong?
Best Reagrds
Espen
Norway
Hi Espen,
I'm sorry to hear that you're facing trouble with it. Under the General - Forest Stats window, you can check more details, and it should give you a hint of where the problem might be. Is the Surface Area enabled? Also, please try adjusting the Distribution > Density values.
In case of any further troubles with it, as it's really hard to say what's happening exactly in your scene just from the provided description, if possible, please feel free to send us your scene (ideally simplified and containing just this problematic object(s)) to helpdesk@itoosoft.com to check it here.
