Author Topic: Forest Edge doesnt apply - 3dsmax24 + FP 826  (Read 20528 times)
zules
« on: September 05, 2024, 10:44:08 am »
i'm having trouble to get Forest Edge working on my project.
I'm using Nouvelle Mesure set with the last version of FP, but even while using Material/Optimize button/apply Forest Edge, it doesn't apply no Forest Edge map on the object's material. Neither is the effect visible during rendering.
Is it a known problem ? I can share the FP objects if needed.
JG
Re: Forest Edge doesnt apply - 3dsmax24 + FP 826
« Reply #1 on: September 05, 2024, 10:49:59 am »
I'm sorry to hear you're having trouble with it. Could you please specify which renderer you’re using and its version? Also, if possible, please feel free to send us your scene - ideally simplified and containing only the problematic object(s). Thank you in advance for any further details you can share with us or our user community, as it may help others who encounter similar issues.
zules
« Reply #2 on: September 05, 2024, 10:58:05 am »
Corona 12 :)
Just sent it !
Thx :)
« Reply #3 on: September 05, 2024, 11:38:11 am »
Replied by email.
zules
« Reply #4 on: September 05, 2024, 11:39:36 am »
"If you want to automatically assign the Forest Edge map to the Opacity slot of the corresponding material(s) (the grassy closter corona in your case) using the Material Optimizer tool (though you can always add it manually), ensure that the Material is assigned to the items in the Geometry > Material slot. "
Add the answer for the community :)
Thx iToo :)
Jens meyssen
« Reply #5 on: December 17, 2024, 01:30:09 pm »
Currently experiencing the same issue, tho I have forest edge applied everywhere it should be applied.
Please advise!
« Reply #6 on: December 20, 2024, 08:39:51 am »
Hi Jens,
Please feel free to send us your scene - ideally simplified and containing only the problematic object(s), and we'll check it here. Also, please specify which renderer you’re using and its version. Thanks in advance.
