Author Topic: Creating randomised paving blocks  (Read 3026 times)
HF4101
« on: March 09, 2017, 03:26:44 pm »
I'm trying to create an area filled with 3 sizes of paving block. All are the same height, just vary on the width. The closest I can get is this kind of arrangement. I tried using a 'full' distribution with collisions at 105%, but the object collision takes effect vertically too.
I've also tried distributing along a line, but this only allows for a constant spacing as far as I can see.
Is this possible with Forest Pack?
Re: Creating randomised paving blocks
« Reply #1 on: March 09, 2017, 04:15:19 pm »
Thought using this work-flow can be handy when distributing "circular / spherical objects" as for example shown on following "crystals population (or any other custom objects)" thread, in this case a simple RailClone style will give you a much better results.
Let me add, that overall the Collisions feature might cause a significant performance hit on large distributions because of very low efficiency of this method - all items need to be generated and later a huge amount of those might be discarded, which might take time & system resources.
HF4101
« Reply #2 on: March 14, 2017, 09:50:15 am »
Thanks for your reply. I managed to get a good result using Railclone.
