Author Topic: Refreshing surfaces after moving, adding multiple surfaces  (Read 4100 times)
BL1193
« on: July 19, 2016, 08:29:33 pm »
How is refreshing handled in the latest release when moving the surface area?  The tutorial had a refresh button under the Geometry window.
Even when I move a surface and create a new fp source from the new surface position, it populates at the original position.  Reseting xref does not fix.
How can I add multiple scattering surfaces?  I can add multiple surfaces by list, but they are set to exclude.
Using 3dsmax 2014 and fp 5.1.0
EDIT:  Found it.  My bad.
« Last Edit: July 20, 2016, 07:32:54 am by BL1193 »
