Author Topic: Shingle wall problem  (Read 2654 times)
PC9708
« on: June 07, 2023, 12:41:27 am »
Hi there,
I need help with the issue I have with the shingle wall I am trying to make. In particular, I have a problem with the corner.
I have 3 meshes plugged into the randomize node in the default slot and 3 meshes plugged into the randomize node in the START and END slots.
It is working well where the start is, but at the END, I am getting overlaps. If I disable default meshes, the corner will be generated as I wanted it to be ( check image ), but as soon as I plug in default meshes, some of the meshes will overlap with the END meshes and some of the END meshes will be terminated.
I tried with the padding, but it doesn't work. It is like changing the seed.
Any idea how to solve this?
Re: Shingle wall problem
« Reply #1 on: June 07, 2023, 08:05:56 am »
If possible, please feel free to send us your scene (ideally simplified and containing just this problematic object(s)) to helpdesk@itoosoft.com to check it here. Thanks in advance.
PC9708
« Reply #2 on: June 07, 2023, 12:53:18 pm »
Hi Michael,
Thank you for the response. I just sent a scene simplified scene to the helpdesk.
Best regards
« Reply #3 on: June 07, 2023, 01:45:07 pm »
Replied by email.
