Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Purge geometry
« previous
next »
Print
Pages: [
1
Author
Topic: Purge geometry (Read 2670 times)
Viz3D
Newbie
Purge geometry
on:
January 19, 2022, 10:35:12 am »
is there a way to purge geometry that's been imported through library (in "forest templates" folder) and is no longer in use (deleted from the geometry list)?
Thanks in advance.
Logged
www.viz3d.gr
ITOOSOFT
Hero Member
Re: Purge geometry
Reply #1 on:
January 19, 2022, 10:44:12 am »
Hi, this should happen automatically on scene save as long as the Forest Object used to load the object originally hasn't been deleted. Alternatively, you can clean up the forest templates layer manually by selecting unused objects using an option in the Forest Toolbox script which is available here:
https://forum.itoosoft.com/forest-pro-(*)/scripts-for-forest-pack/msg30594/#msg30594
I hope that helps,
Logged
Viz3D
Newbie
Re: Purge geometry
Reply #2 on:
January 19, 2022, 10:51:11 am »
You are right Paul. I was testing this in an unsaved scene.
After opening an already saved scene though there was no need for purging.
Thank you!
Logged
www.viz3d.gr
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Purge geometry
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
