Author Topic: Collapse optmize material to item  (Read 4496 times)
Max Daiber
« on: August 05, 2021, 07:55:00 pm »
Is there a way to collapse the color corrections?
Let me explain. I use the color correction menu to quickly change the tones of leafs, because it really faster when trees have multiple materials. I do this with each species indivudually (1 species = 1 forest).
What I would like to do, is to combine those forest objects into 1 after ajusting all tones.
Re: Collapse optmize material to item
« Reply #1 on: August 06, 2021, 09:45:27 am »
Thanks for your question. I'm afraid at present that isn't possible. The colour correction is done using the Forest Colour map which takes its settings from the Forest Object itself. I'm afraid to edit objects separately you'd need to use standard Colour Correction maps.
Many thanks,
