Author Topic: FPro 916 issues  (Read 12232 times)
spike
FPro 916 issues
« on: November 26, 2024, 04:20:11 pm »
after installng FPro 916, VRay 'stopped' rendering some Chaos Cosmos foliage (Cherry Laurel 002_019) correctly, the leaves and flowers were not rendering, only the bark objects.
Going back to FPro 913 solved it.
« Last Edit: November 26, 2024, 04:22:59 pm by spike »
Re: FPro 916 issues
« Reply #1 on: November 27, 2024, 09:37:52 am »
Hi, What V-Ray version do you use ?
If you use V-Ray 7, please be sure is upgraded to the latest release.
« Last Edit: November 27, 2024, 11:41:48 am by iToo »
spike
Re: FPro 916 issues
« Reply #2 on: November 27, 2024, 01:01:54 pm »
using VRay 6.2.1
Re: FPro 916 issues
« Reply #3 on: November 28, 2024, 09:38:58 am »
It's strange. We made some tests here, and everything seems correct. Using 3DS Max 2024 & 2025, V-Ray 6.2.1 and 6.1.1, both CPU and GPU.
This error was happening with beta versions of V-Ray 7 (stable version is correct).
I would suggest you download latest V-Ray 6 from Chaos site and reinstall it, to be sure you have same version than us.
« Last Edit: November 28, 2024, 12:26:38 pm by iToo »
spike
Re: FPro 916 issues
« Reply #4 on: November 28, 2024, 12:47:56 pm »
I am using Max 2023, but about a month ago things started going wrong, it may have been a Win11 update, other people reported similar problems ?
Now some startup maxscipts aren't working, it affects VRay the most, having to keep pressing VRay menu registration to get Chaos Cosmos to appear as a menu, might be related ?
Re: FPro 916 issues
« Reply #5 on: November 28, 2024, 01:22:56 pm »
Other users reported problems with the latest Window 11 update and maxscript. You can find the discussion here.
But theorically that should not affect V-Ray rendering.
spike
Re: FPro 916 issues
« Reply #6 on: November 28, 2024, 03:49:08 pm »
Links solution worked !
2 months of tedium over with, hopefully.
Re: FPro 916 issues
« Reply #7 on: November 29, 2024, 08:26:54 am »
Nice. I'm glad it worked.
