Author Topic: Color Correction - Brigtness  (Read 3687 times)
RealViz
    • RealViz
« on: September 21, 2021, 01:07:29 pm »
Hi, after a long time I wanted to use the function to change the material directly in FP. Unfortunately the Brightness item does not work as expected. All colors are completely oversaturated. If I apply Brightness directly to the texture via Photoshop the result is completely different. Would it be possible to add e.g. Gain? Gain works on most cases much better. Thanks.
edit: And also the range of the Brighness function does not seem to be very linear. -0.2 is almost black and 0.2 is almost white.
« Last Edit: September 21, 2021, 01:10:52 pm by RealViz »
RealViz
    • RealViz
Re: Color Correction - Brigtness
« Reply #1 on: September 21, 2021, 01:26:57 pm »
I figure your interpretation is similar to the "legacy" brightness in Photoshop. Would it be possible to override it to a standard one where it doesn't cut colors and thus resaturates the dominant color?
« Reply #2 on: September 21, 2021, 01:50:56 pm »
Thanks for the feedback about the colour correction tools. I'll pass it on to the development team. I seem to recall that we emulated some built-in max Colour correction maps but they'll investigate further.
Best,
RealViz
    • RealViz
« Reply #3 on: September 22, 2021, 09:35:07 am »
Thanks! Now is Brightness unusable :-(
Gain or better intepretation of Brightness like Photoshop is the solution.
