Forest Pack => Forest Pro (*) => Topic started by: NE4992 on June 07, 2016, 03:02:16 pm
Title: Color splotches all over the scene when using 2D geometry
Post by: NE4992 on June 07, 2016, 03:02:16 pm
I tried to search for this issue but can't find anything, so if there's already a thread about it I apologize.
I'm using Mental Ray and when using 2D geometry (from the built-in library) I got color splotches all over the scene (not only forest objects). It seems related to the forest material shader.
Here's an example :
(http://i.imgur.com/FrVRhoil.jpg)
Appart from removing the forest material shader and applying directly the standard to the geometry I can't find a way to avoid these color splotches, is this a known issue and is there a workaround?
Title: Re: Color splotches all over the scene when using 2D geometry
Post by: iToo on June 08, 2016, 12:00:27 pm
Hi, first time we find a similar problem. No idea what may cause it.
Please, would you send us (http://forum.itoosoft.com/index.php?topic=3648.0) a simplificated scene ? We'll do some tests.
