Forest Pack => Forest Pro (*) => Topic started by: Alexey Kuznetsov on September 03, 2012, 05:31:26 pm
Help me please. Then i update FP to 3.9.4 version color tint work in scanline render only. In MR color tint dont work.
3dmax 2012 SP2 update 9, FP 3.9.4.
Do you use 3D Objects or billboards ? Standard meshes or MR Proxies ?
Are you using Forest Material or Forest Color ?
If possible, please post a test scene and we will check it.
I don`t use 3D Objects. Standard meshes. I use Forest Material, that is automatically.
I cannot reproduce the problem here (see attached sample). Please, upload your scene to compare.
My test scene.
your scene work, as well as any from your own site. And those that I create, I have stopped working.
Ok, i have found the problem: Display->Render->Mode was set to "Meshes", but it should be "Automatic". The Meshes mode handles Forest as a standard mesh; doesn't create instances and disables some rendering functions in Mental Ray and Ray (as tint).
Thank you so much!
