Author Topic: I want to confirm rendering without any licenses, please.  (Read 3296 times)
cc8boy
    • C7design
« on: October 08, 2014, 03:53:10 am »
Dear developers,
I’m going to do a long time rendering. I want to confirm this that I can doing these without a license again.
This is my procedure,
1.       This is my independent renderfarm in the independent LAN without any licenses of iToosoft plugins.
2.       I just installed all the iToosoft plugins in render slave mode with my software package in these computers in this LAN .
3.       I open my scene file (I created in another LAN with network license) in MAX2012 in one of my render slave computer.
4.       I just open the render setup dialog and check the “net render” option. And I am going to summit the render job to my backburner in my MAX2012 window in this LAN without any licenses.
My questions are these,
1.     Will there be any problem I continue my work in my LAN B with my iToosoft plugins in the same time when I render this scene in my LAN A without any licenses?
2.     Must I copy all the texture maps and all the distribution maps to my project folder in my renderslaves ?
I must confirm these before doing the job, please answer me as soon as possible. Thank you very much.
Re: I want to confirm rendering without any licenses, please.
« Reply #1 on: October 08, 2014, 09:16:21 am »
Hi, replying to your questions:
1. No, there are not problems to submit a job to the queue and render it without a license.
2. Distribution maps and other essential files are copied locally by the setup program, but always it's a good idea to check all paths using Asset Tracker.
In any case, i suggest you test a few frames before submitting a long render, to be sure everything is correct.
cc8boy
    • C7design
« Reply #2 on: October 08, 2014, 11:36:39 am »
Thanks for the reply.
I have another question. My friend in my another office,  he know that he can not edit the objects of iToosoft without a license.  He also want to know wheather there is any problem that he just change the path of texture bitmaps in material editor or asset tracking dialog window and save the scene before rendering.
« Reply #3 on: October 08, 2014, 11:55:09 am »
Yes, he can modify the paths without problems.
