Author Topic: Edge mode issues  (Read 2731 times)
GR4367
Edge mode issues
« on: February 16, 2022, 07:13:21 pm »
Hello there,
I´d like to ask you guys if this is a bug or I doing something wrong.
After apply forest edge, branches still visible.
Thx!
RealViz
    • RealViz
Re: Edge mode issues
« Reply #1 on: February 17, 2022, 06:26:21 am »
Please post the scene, can't identify the problem.
« Reply #2 on: February 17, 2022, 11:25:04 am »
In this case, it is to be expected. Edge modes works by examining each element. It identifies the lowest vertex of that element and then checks to see if it is outside the area. If it's outside it's removed, if it's inside it's retained. In this example those branches are still inside the area so they are kept. You might be better using Size mode instead.
Cheers,
« Last Edit: February 18, 2022, 04:22:13 pm by Paul Roberts »
GR4367
« Reply #3 on: February 18, 2022, 04:17:27 pm »
huum
Ok then, thx for letting me know.
