Author Topic: Warning when creating a library  (Read 2893 times)
iToo_Butler
    • DJS CGI
« on: November 20, 2015, 04:38:21 pm »
Afternoon,
I'm trying to create a ustom library for a pack of  trees I haave purchased but when I choose the maxfile in the item settings dialog, I get the following warning ----- "It is not possible to do this operation if a maxfile if being created. Please, open the Library Browser from the Max Modify panel and try again." The select object windows appears next, but doesn't contain any objects to pick, even though the maxfile I have picked contains the tree.
When I open the browser and try again I get the same message.
I'm a bit stuck as to what to try, I have tried goruping the tree in the maxfile and also tried attached all the object so they are one object. Neither have worked.
Cheers,
Andy.
Cheers,
iToo_Butler.
Re: Warning when creating a library
« Reply #1 on: November 20, 2015, 04:56:58 pm »
Hi, you must create a Forest object, go to the Modify panel and open the Library Browser from there:
Although the Library interface is the same, some Max operations are not allowed when an object is being created. That's all.
Kind regards,
