Author Topic: Compatibility of corona 7  (Read 2812 times)
Haitao
« on: August 19, 2021, 08:23:56 am »
Please update the adaptation compatible with corona 7 officially. At present, it takes 3 minutes to analyze some scenes of forests under the use of corona 7! It is recommended to optimize! :( :( :( :( :(
Re: Compatibility of corona 7
« Reply #1 on: August 19, 2021, 09:37:03 am »
Sorry to hear you are facing these issues. Would it be possible to send us the problematic scene so that we can dig a little deeper to understand where the bottleneck is? You can send it to helpdesk@itoosoft.com, using a service like wetransfer for large files.
I would also like to mention that Corona and several other renderers actually support us via our API, so there is a limit to how much we are able to do on our side. There is also a known issue when using Corona Proxies, especially animated proxies, that requires a fix from the Corona side. If you are using proxies, that could be it. You can read more about it here: https://forum.itoosoft.com/forest-pro-(*)/fpp-corona-animated-proxies-and-scene-parsingprep-time/
Best,
« Last Edit: August 19, 2021, 10:47:01 am by Paul Roberts »
Haitao
« Reply #2 on: August 19, 2021, 10:26:30 am »
Thank you, but I can't open this page. Can I send a complete link? In addition, I seem to have solved this problem in the process of retesting. It seems to be the problem of corona displacement map. It can be easily rendered without displacement map.
« Reply #3 on: August 19, 2021, 10:57:19 am »
Apologies, I've updated the link. If displacement was enabled though, then that's probably the explanation.
All the best,
