Author Topic: Re-Seed after Store Random  (Read 22379 times)
CharlyRT
« on: May 23, 2025, 06:34:36 pm »
Usually I dont use Item editor, but while testing the new behavior of Re-Seed on Custom Edit I noticed that when activate Store Random I cant Re-seed, ok, thats the behaivior of that tool, but what about when I change it back to Generate and then custom edit again? Could we have a Free store random? only recreate a Forest object we can have the re-seed control again.
Re: Re-Seed after Store Random
« Reply #1 on: May 26, 2025, 09:44:05 am »
It's not necessary to switch to the Generate mode — simply re-enable the corresponding Transform > Translation / Rotation / Scale values, and the Re-Seed button will affect them again. I hope this helps.
CharlyRT
« Reply #2 on: May 26, 2025, 04:47:42 pm »
Thanks for responding Michal, thats it.
I didnt quite understand what "Transform parameters will be reset"
Could this warning be edited so its more clear, "Transform parameters will be turned off" rather than will be reset.
« Last Edit: May 26, 2025, 05:13:58 pm by CharlyRT »
