Author Topic: Copy all settings from one forest to another  (Read 4241 times)
bimmer88
« on: January 21, 2014, 04:23:56 pm »
I was wondering is there a way to copy all the setting from a forest to a another separate geometry, ie scale, rotation,distribution.
I know i should be including all the geometry in the first forest but using it along spline. In some cases this not possible, i have to slightly rotate the forest according to the desired view angle.
Also is there away to align forest objects perpendicular to spline?
FYI i'm a new user. ;s
Thanks in advance.
Re: Copy all settings from one forest to another
« Reply #1 on: January 21, 2014, 05:22:39 pm »
No, there is not any option to copy settings between Forest objects, because in each case the parameters to copy or keep would be different. And obviously, copying all settings has the same effect that cloning the object.
I don't understand well the problem you describe. Please, would you include some screenshots ? Thanks.
